  2. Login, Licensing & Installation
  3. OrCAD X 26.1 Academic License – Intermittent LMC-07702 Validation...
  • Subscribers 5
  • Views 208
OrCAD X 26.1 Academic License – Intermittent LMC-07702 Validation Error
GL20261101989
GL20261101989 14 days ago
Hello Cadence Support Team,
I am a university student using OrCAD X Professional Plus 26.1 with an academic trial license.
I have successfully completed student verification and signed in to my Cadence account. However, while using OrCAD Capture CIS, I repeatedly encounter the following error:
WARNING (LMC-07702): Unable to validate the licenses. Repeated failures will cause the application to exit.
Additional error codes: 103 and 1993.
The application launches successfully, but the license validation error occurs intermittently during normal schematic editing.
I have tried both my university's wired network and my iPhone's mobile data connection. The issue continues to occur.
My academic license is expected to remain valid until May 1, 2027.
Could you please advise how to diagnose and resolve this issue? In particular, I would like to know whether this is related to cloud license validation, device registration, or the local licensing service.
Thank you for your assistance.
  • GL20261101989
    0 GL20261101989 13 days ago
    Update – November 5, 2026: Reproducible Licensing Failure and Capture Crash
    Hello Cadence Community,
    I would like to provide an update regarding the intermittent licensing issue on my university laboratory desktop.
    Software and license:
    • OrCAD X Capture CIS 26.1 P001 (Build 4490145)
    • OrCAD X Professional Plus Single-User Academic License (POX300)
    • License entitlement expires on May 1, 2027
    New observations:
    1. OrCAD X Capture launches successfully and can remain on the Start Page for approximately 10 minutes without any licensing warnings.
    2. When I open my existing LLC converter project (llc_test.opj), the following warning appears immediately:
      WARNING(LMC-07702): Unable to validate the licenses ... (103) Internal error condition (1993)
    3. To determine whether the issue was related to my original project, I created a completely new test project named error_test.opj.
    4. During the process of opening the new schematic, Capture unexpectedly crashed.
    5. The generated crash report contains the following information:
      • Exception: ACCESS_VIOLATION
      • Faulting module: orDb_Dll64.dll
      • Function: DboPage::GetOwner
      • Application: Capture 26.1 P001
      • Crash timestamp: November 5, 2026, 15:02:15 (UTC+8)
    Previous troubleshooting:
    • Updated the license using the Cadence installer.
    • Restarted Windows.
    • Tested both the university Ethernet connection and a separate mobile internet connection.
    • Checked Windows Defender Firewall permissions for Cadence applications.
    • The license temporarily worked after updating, but the issue returned.
    • The same academic license was successfully used on my personal laptop on November 4, including PSpice simulations.
    I have also previously encountered LMC-021993 when launching PSpice.
    At this point, I cannot determine whether the licensing errors and the Capture access violation share the same underlying cause.
    Could a Cadence engineer please advise:
    1. What does internal error condition (1993) indicate in the Single-User License validation process?
    2. Could switching the active academic Single-User License between two computers cause this behavior?
    3. Are there any specific licensing diagnostic logs or troubleshooting procedures recommended for OrCAD X 26.1?
    4. Could this issue be related to a known defect in Capture 26.1 P001?
    I have retained the Capture crash report and memory dump and can provide them through an appropriate private support channel if needed.
