  2. OrCAD X Presto PCB
  3. How to change the design outline width & height
  • State Suggested Answer
  • Answers 1
  • Subscribers 18
  • Views 3865
Schulz Jordan
Schulz Jordan over 3 years ago
It seems like there is option to edit the design outline once you place components. I was able to edit the outline prior to component placement but now I can't. The properties window shows no option to edit it. PFA of image of same
  • mahimag
    mahimag over 3 years ago +1 suggested
    From the screenshot it looks like you are in add connect command. Without enabling any command, if you just click on the Design Outline, the outline shape is highlighted and if youright mouse click there…
  • mahimag
    0 mahimag over 3 years ago
    From the screenshot it looks like you are in add connect command. Without enabling any command, if you just click on the Design Outline, the outline shape is highlighted and if youright mouse click there you have an option to edit boundary. Vertices also gets highlighted to edit.
  • passedpawn
    0 passedpawn over 2 years ago in reply to mahimag
    Is it possible to ADD a vertice to an existing outline?
