  2. OrCAD X Presto PCB
  3. OrCADX Tip of the week: How to open existing board files...
  • Subscribers 15
  • Views 1149
OrCADX Tip of the week: How to open existing board files in the Presto PCB Editor from OrCAD X Capture?
PCBTech
PCBTech over 1 year ago
To do this, set OrCAD X Presto as the active layout tool in OrCAD X Capture. This will open any associated layout in OrCAD X Presto.
Perform the following steps to set OrCAD X Presto as the active layout tool:
1. Choose PCB > Design Sync Setup to select the layout tool.
2. In the Design Sync Setup dialog box, choose OrCAD X Presto from the Select Layout Tool drop-down menu.
3. Select OK to save the settings.
4. Select a board file in the Project Manager, right-click, and choose Launch PCB Editor.
5. The board will be opened in OrCAD X Presto.
Note: This setting will be saved only for the current project.
