  2. OrCAD X Presto PCB
  3. How to do pin swapping in OrCAD X Presto
  • Subscribers 16
  • Views 1572
mahimag
mahimag over 2 years ago
Let us explore how to do simple pin swapping in OrCAD X Presto. First, locate the move command on the floating toolbar and right-click on it:
The swap command will appear as part of a group of commands. After clicking on it, it will open the following floating menu:
To swap pins, select the Pins tab. You can also choose the options like “Ripup Routes” and “Display Rats On Pick100
Adjust your selection filter to Pins only:
Now, select the two pins you want to swap:
As a result, the pins will be swapped and the rats will showcase it:
Notice that there is a check box to swap attributes.
Once you select this, Pins are swapped with their attributes, which you can specify in the Attributes section of the Properties panel.
Have you tried this feature?
