  2. OrCAD X Presto PCB
  3. How to set text blocks in OrCAD X Presto PCB Standard v...
  • State Suggested Answer
  • Answers 2
  • Subscribers 18
  • Views 6539
How to set text blocks in OrCAD X Presto PCB Standard version
Stevenson
Stevenson over 2 years ago
By default, the text width is 0 for all text blocks. How to set up the text block parameters?
  • techiecs
    techiecs over 2 years ago +1 suggested
    In OrCAD X Presto PCB Standard, disable all objects and enable only 'Text' in the Selection Filter under Properties menu. After this, select any text in the Presto design canvas, after you select a text…
  • Malokani
    Malokani over 2 years ago in reply to Stevenson +1 suggested
    Hi Stevenson, There are lots of things that are missing in OrCAD-x presto. You have to open your design in PCB Editor and then setup Text Block in PCB Editor. Then you can use those settings in Orcad…
  • techiecs
    techiecs over 2 years ago in reply to Stevenson +1
    There is a request for this option to modify Text Block size and parameters under it to be editable in OrCAD X Presto submitted to Cadence.
  • passedpawn
    0 passedpawn over 1 year ago in reply to techiecs
    Unless I missed it, you STILL cannot define the text block sizes in Presto.  All widths are the default - zero  So, without opening the board in a different program, it's impossible to have text on the PCB.
    Presto has even had a major version release, and this is still missing.  Totally unsatisfactory.
