  2. OrCAD X Presto PCB
  3. OrCAD X Presto PCB 23.1 : How to change the layer of a ref...
  • Replies 7
  • Subscribers 17
  • Views 4552
OrCAD X Presto PCB 23.1 : How to change the layer of a ref design
SamTronic
SamTronic over 2 years ago
On OrCAD X Presto 23.1, how I can change the layer of a reference design of a component ?
If I select "Text" on the filter, the field of the layer is in gray, and it is impossible expand the field :
What I wanted to do initially, is to not display some ref design (for example on a high density PCB).
Is it a way to do that without changing the layer of the ref design ?
  • Malokani
    Malokani over 2 years ago in reply to mahimag +1
    Hi Mahimang, Where I can find the CCR list and how I can know when the CCR ID 3056195 be released. I had asked last time the there was no Via structure in the OrcadX Presto standard license and someone…
  • Malokani
    0 Malokani over 2 years ago in reply to mahimag
    Hi Mahimang,
    Where I can find the CCR list and how I can know when the CCR ID 3056195 be released. I had asked last time the there was no Via structure in the OrcadX Presto standard license and someone here said that it will be in CCR ID xxxx. I do not remember the ID. Is it possible that I can track?
    Abdul
  • mahimag
    0 mahimag over 2 years ago in reply to Malokani
    Hello Malokani , you can check this in README_CCR.txt file available with each release on downloads.cadence.com.
