  2. OrCAD X Presto PCB
  3. How to generate Gerber files including board outline layer...
  • State Suggested Answer
  • Answers 1
  • Subscribers 17
  • Views 3609
How to generate Gerber files including board outline layer in Orcad X Presto
VP20240715996
VP20240715996 over 2 years ago
I am trying to generate Gerber files in Orcad X Presto for making pcb.
However, the pcb manufacturer told me that my Gerber files missed the board outline layer (all other *.art files are ok).
Please let me know how to generate Gerber files including board outline layer in Orcad X Presto.
Thank you for your help!
  • techiecs
    techiecs over 2 years ago +1 suggested
    In the Export to Manufacturing window in OrCAD X Presto, if you select the 'Configure Artwork Films..' option, here we can add the Board Geometry/Design_Outline under the required films before generating…
  • techiecs
    0 techiecs over 2 years ago
    In the Export to Manufacturing window in OrCAD X Presto, if you select the 'Configure Artwork Films..' option, here we can add the Board Geometry/Design_Outline under the required films before generating the artwork.
    Also, ensure that undefined line width is not set to zero for each artwork film record if you include the design outline shape in the artwork files.
  • VP20240715996
    0 VP20240715996 over 2 years ago in reply to techiecs
    Thank you for your reply.
    At present, I can create "Design_Outline.art" file as detailed guide in https://www.ema-eda.com/how-to-page/how-to-configure-artwork-films-in-orcad-x-presto/
    However, when I open this Design_Outline.art, the width of outline is too big. Meanwhile, this outline should have about zero width.
  • VP20240715996
