  2. OrCAD X Presto PCB
  3. Trace loop in OrCad X
  • State Verified Answer
  • Subscribers 17
  • Views 2327
MB202410295758
MB202410295758 over 2 years ago
I noticed that the algorithm that manages the elimination of trace loops does not work correctly, even if the related option is set.
It often happens that the loops remain:
Is it a known bug?
  • mahimag
    mahimag over 2 years ago +1 verified
    Hello MB202410295758 , are you checking this in OrCADX Presto with "Remove/Prevent Loops"? Also, which version and hotfix you are on?
  • mahimag
    +1 mahimag over 2 years ago
  • MB202410295758
    0 MB202410295758 over 2 years ago in reply to mahimag
    yes, the option "Remove/Prevent Loops" is checked but it doesn't seem to work properly.
    I am using orCDA X Presto 24.1 (without hotfix)
  • mahimag
    0 mahimag over 2 years ago in reply to MB202410295758
    may be this is database specific. I have checked with sample database in same version and this is working fine. We will contact you via seprate channel to discuss more on this.
