  2. OrCAD X Presto PCB
  3. How to split the etch plane with same net name
  • State Suggested Answer
  • Answers 1
  • Subscribers 17
  • Views 2163
RohitRohan
RohitRohan over 1 year ago
Hai Community,
I have a PCB board where the bottom layer is defined as a GND plane. I would like to split this plane into two separate sections while keeping both sections assigned to the same net name (GND).
Could anyone please suggest the best method to achieve this? I am looking for guidance on how to effectively split the plane while ensuring proper electrical performance and connectivity.
Your valuable suggestions and insights would be greatly appreciated.
Rohit Rohan
  • vidhyaparameswari
    vidhyaparameswari over 1 year ago +1 suggested
    Hi Rohit, Currently, Presto does not have a built-in feature that allows users to easily create two separate planes for a single net on the same layer. Due to these limitations, you will need to manually…
  • vidhyaparameswari
    0 vidhyaparameswari over 1 year ago
    Hi Rohit,
    Currently, Presto does not have a built-in feature that allows users to easily create two separate planes for a single net on the same layer. Due to these limitations, you will need to manually create the shapes according to your requirements.
  • RohitRohan
    0 RohitRohan over 1 year ago in reply to vidhyaparameswari
