  2. OrCAD X Presto PCB
  3. How to use coordinates to quickly locate the add line operation...
  • Subscribers 16
  • Views 1970
How to use coordinates to quickly locate the add line operation on OrCAD X Presto PCB
Zhifeng Jin
Zhifeng Jin 6 months ago
Hi brothers, I have been learning OrCAD X Presto PCB recently. Is there a way to accurately and quickly input coordinate positioning like Allegro editor when using add line drawing?
For example:
Enter command x 10 100
  • Zhifeng Jin
    0 Zhifeng Jin 6 months ago
    I've been working on this problem for a long time, and it seems like I haven't found a good solution.
    I feel like OrCAD X PCB Presto 24.1 is still just a semi-finished product, and many basic functions haven't been developed yet.
    Just like when designing PCB Footprint, you cannot modify or input the coordinates of the two ends of the 2D line。
  • DG202504226528
    0 DG202504226528 6 months ago in reply to Zhifeng Jin
    Yeah, I've tried different ways and it's a no go for that one.  Only solution seems to be open the board file into the legacy tool, edit the line and then save and re open Presto.
    I'm hoping the October update will bring a resolution to some of these issues.
  • Zhifeng Jin
    0 Zhifeng Jin 6 months ago in reply to DG202504226528
    Thank you for your reply.
    As you mentioned, the best solution currently is to go back to the Allegro editor and use coordinate positioning to draw the silkscreen 2D line of the PCB footprint.
  • Zhifeng Jin
    0 Zhifeng Jin 1 month ago in reply to DG202504226528
    Orcad x 25.1 has been released for some time now. Can precise positioning be achieved by inputting coordinates in Orcad x professional plus? For example, if I need to draw a 2D board outline, can I accurately locate the line drawing operation by inputting coordinates?
