  2. OrCAD X Presto PCB
  3. Search Panel missing in OrCAD X Presto after floating -...
  • Subscribers 20
  • Views 2264
Search Panel missing in OrCAD X Presto after floating - Need help with UI reset
HY202510149941
HY202510149941 11 months ago
I am reporting a UI bug in OrCAD X Presto where the Search Panel has disappeared and become completely inaccessible.
Problem: After using the Search Panel as a floating window, it vanished. It is now unresponsive to keyboard shortcuts, menu toggles, and even a full software reinstallation. It appears the UI layout data is corrupted and persisting in the local configuration files.
Request:
  1. Please provide instructions on how to hard-reset the UI layout to factory defaults.
  2. Which local configuration files or registry paths should be manually cleared to perform a "clean" reinstall that wipes previous UI states?
Best regards,
  • Gowtham P
    0 Gowtham P 11 months ago
    HY202510149941
    You can try enabling the window by navigating to View > Panels > Search.
    If the Search pane still doesn’t appear, the next step would be to close all the Presto instances, then rename the “Cadence Design Systems” folder located under
    Computer\HKEY_CURRENT_USER\Software\ in the Registry Editor.
    Before making any changes in the Registry Editor, I strongly recommend creating a backup of your registry.
  • WW202601059925
    0 WW202601059925 10 months ago
    This behavior strongly suggests corrupted UI layout data stored in local user configuration.
    A proper fix would be to fully reset the UI by removing all local OrCAD X Presto user profile/configuration files (AppData) and related registry entries, as a standard reinstall does not clear persisted UI state.
    Pls advise the exact files/paths that should be deleted to perform a true clean UI reset.
  • EA202612309955
    0 EA202612309955 10 months ago
    I can't believe the Search Panel is missing after floating! It's wild how a simple bug can throw everything off. I was just browsing through some posts on the Cadence Community and found that removing local files is essential for getting back to a working state.
