  2. OrCAD X Presto PCB
  3. PCB Footprint Text on Silkscreen Layer
  • Subscribers 18
  • Views 822
ddchar
ddchar 4 months ago
My PCB components have the footprint names displayed in Presto.  These are on the "Device Type/Silkscreen_Top" layer.  The footprint names don't appear in the silkscreen artwork, but this does cause (minor) problems when trying to move reference designator text, for example (I have to move this text out of the way to select the RefDes).  What I would like to do is turn off this layer without turning off everything on the silkscreen layer.  Is there any way to do this?
  • Ulf K
    0 Ulf K 4 months ago
    Since I do not work using Presto but rather the "old fashon" GUI, what I am about to suggest may not be relevant but here it goes:
    Whenever encountering a footprint with IMO excessive amount of silk-screen texts, I either delete the text or, if I for some reason want to retain it in the .BRD file data, I create a new subclass like "SilkScreen_Hidden". I then change the properties of the particular text string to that sub class after which I make that class invisible.
  • ddchar
    0 ddchar 4 months ago in reply to Ulf K
    Thanks for the info.  I can delete the text in the .brd file.  I looked for a way to delete the footprint name when editing the footprint in Allegro, but this text does not appear.  Other text values (e.g., tolerance, ref des, etc.) are visible, but I couldn't find a setting in which the footprint text was visible (everything on Silkscreen Top was set to visible).
    I haven't figured out how to change the subclass in Presto.  I can see the Subclass/Layer on the Properties panel, but it doesn't appear to be editable.
