  2. OrCAD X Presto PCB
  3. How to Enable Chinese or Japanese UI in OrCAD X Presto
  • Subscribers 16
  • Views 50
vidhyaparameswari
vidhyaparameswari 4 days ago
OrCAD X Presto provides local language support for Chinese and Japanese. When enabled, menus, dialog boxes, messages, datatips, and related UI elements can be displayed using the selected regional language and font.
1.To enable the local language in OrCAD X Presto, go to Edit > Preferences > Language > Settings, select Use Local Language and Localized Menus, and then choose the appropriate Locale Font from the pull-down list.
2.Close OrCAD X Presto, change the system language (system locale) and select either Chinese or Japanese as the regional format, then restart OrCAD X Presto. After restarting, the user interface text, including menus, dialog boxes, messages, and datatips, will be displayed in the selected local language.
3.The same language preference is also applied to utilities such as Constraint Manager.
If you prefer to keep the menus in English while displaying other UI text in the selected local language, deselect Localized Menus using Edit > Preferences > Language > Settings, exit OrCAD X Presto, and restart the application.
Now, you can see the Menus in English. Try out the above steps and feel free to put the questions.
