  2. Allegro X APD
  3. Question about shield
  • Subscribers 69
  • Views 14784
Thinker
Thinker over 17 years ago
I am new in 16.2, and think constraint driven design is the way to go. I found there is " shield" under CM-properties-Net-general properties-Shield(shield/type).  did anyone use this function? does means the shielding trace will be add in automatically?  how it works?
Need help here, and more question to be posted.  Thanks
  • jhorner
    jhorner over 17 years ago
    This attribute is used to control the Allegro PCB Router. It is used only in the autorouter environment.
