  2. Allegro X APD
  3. How to add constraint area in apd16.2?
  • Subscribers 72
  • Views 17576
Alice
Alice over 17 years ago
In APD15.7, we can add a constraint area by creating a shape and attach the property. However, I have no idea how to create a constraint area in APD16.2. Anyone can help..
Alice
  • Jeff Gallagher
    Jeff Gallagher over 17 years ago
    How to set up a constraint region in 16.2.
    Lets say we want to create a spacing region:
    Open constraint manager and create a Spacing Rule set for the constraint region.
    1. Open Constraint Manager on the board file.
    2. Select Spacing > All Layers worksheet
    3. RMB on the Objects and select Create Spacing CSet
    4. Type the name of Spacing CSet and change the pin to pin constraints that allow
    pin to pin spacing for the 'special' component.
    Now create a region and assign a spacing CSet to the region.
    1. In Constraint Manager, select Region > All Layers
    2. RMB > Create Region
    3. Give a name to the region, and select Ok.
    4. On the Region worksheet, select the region that you just created, and assign
    the Spacing CSet that you had created in the previous step. The rules of the
    spacing CSet are automatically taken over by the Region.
    Now create a Shape on Constraint Area subclass and assign the region rules to it.
    1. On Allegro, Select Shape > Polygon or Rectangular.
    2. In the Options panel on the Right hand side, select the Class as Constraint
    Region > All.
    3. From the drop down in the options panel, select the Region you had defined in
    the previous step.
    4. Draw the rectangle or polygon around the component.
  • Alice
    Hi Jeff,
    Thanks alot. It works now.
    Alice
    archive over 17 years ago
    The procedure above is correct, but there is additional options you may wish to choose.
    1.  The shape(s) for the Region do not have to be drawn on the All subclass of the Constraint Region class.  You may create the shapes on any etch layer, or the special layers of Outer Layers (i.e. Top and Bottom), Inner Signal Layers, or Inner Plane Layers.
    2.  You do not have to use a Spacing Constraint Set for the Region.  You only have to specify the constraints that you need specifically for this region.  By only specifying the pin-pin constraints that you need, you'll improve the drc performance and you're constraint methodology will be easier to understand.
    3. Regions also support Physical and Same Net Spacing constraints.
    4.  When creating the shape, you can select a Region name from the "Assign to Region" drop down on the Option panel, or you can type in a new name.  Any new name will automatically appear in Constraint Manager in the Physical, Spacing, and Same Net Spacing worksheets.
    Also, in case you weren't aware, there is no limit to the number of shapes that can be part of a Constraint Region.
  • Alfandari
    Alfandari over 16 years ago
    Is this method available in OrCAD PCB Disigner 16.0?
    I can't find the Region in the Constraint Manager.
    I found the Constraint Region Class though.
    I need to specify constraint for specific component, how can I do so? if at all possible?
    Thanks in advance,
    Shai
  • frewahy
    frewahy over 16 years ago
    test
