  2. Allegro X APD
  3. How to void shape for same net Bond Finger in APD16.2
  • Subscribers 69
  • Views 15401
Alice 2009
Alice 2009 over 16 years ago
Hi all,
 I have problem to void the shape from the same net bond finger. Although I have set the shape to bond finger spacing, and set the shape parameter to follow DRC rules for Shape Clearence. Anyone, pls advice.
Currently, I am doing manually work to edit the shape bondary =(
Alice
  • mikem
    mikem over 16 years ago
    One way is to enter in the desired, same net spacing value in Constraint Manager.  Next, go the the command menu and select EDIT>PROPERTIES and select the same net bondfinger/s.  In the Available Properties pop-up window, select "No_Shape_Connect".  The dynamic shape should immediately void around the bondfinger, if not, update the shape.
  • Alice 2009
    Hi mike,
    It works. Thanks =)
    Alice
