  2. Allegro X APD
  3. How to use "Snap Pick To..." in APD16.2
  • Subscribers 68
  • Views 3355
Alice 2009
Alice 2009 over 16 years ago
There's a function called "Snap Pick To" when I do a move and right click mouse. Is anyonw know how to use it? Will it be the same as the object snap function?
Alice
  • BillAcito
    BillAcito over 16 years ago
    Use the RMB snap menu (e.g. while in "add connect")  to select which object you want "snap" to. As the cursor approaches that object, it should "jump" or "snap" to it. Very handy if you are, to continue the example, trying to connect a route to the center or end of an object, as an example.
    Bill
  • Alice 2009
    Hi Bill,
    How about if I want to move an object? Isst able to move an object with snap from one coordinate(e.g. end of a line) and place on the center of 1 circle?
    Pls advise.
    Alice
