  2. Allegro X APD
  3. How to add a wirebond group on APD15.7
  • Subscribers 68
  • Views 16851
freeda
freeda over 15 years ago
Hi! I should be using a bondfinger and via ring on my wirebond lay-out. But I can't seem to do it because when I add a wirebond, the bondfinger is appearing as default and I can't change it to a via ring if ever I need to drop the stitch on the PWR/GND ring. So, I figured that I need to add a wirebond group in order to do this. But I don't know how to create a wirebond group on APD15.7.
Thanks for your help in advance. :)
Best regards,
Freeda
  • BillAcito
    BillAcito over 15 years ago
    Hi Freeda,
    While in the wire bond command (add) you should be able to type a new group name into the group field in the Options tab.
    For the wire to connect to the ring shape, the net needs a voltage property, and you have to make sure the shape is actually on a correct layer (top / bottom substrate layer).
    Bill
  • freeda
    Hi Bill,
    Thanks. It’s working now.J
    Best regards,
    Feeda
  • Erictc
    Erictc over 15 years ago
    But did anyone know how to delete/purge the Wirebond group in V15.7 ,
    for those not used & will NOT use any more?
  • ozanam
    ozanam over 14 years ago
     I recommend this website
    Sheltered Workshops Sydney
