  2. Allegro X APD
  3. How to generate DIE apart from using DIE text in wizard
  • Subscribers 68
  • Views 16713
lifeuistanea
lifeuistanea over 14 years ago
Hi Guys, Is there any other way to generate DIE symbol apart from using Die text in wizard? For ex: If we want to create Flip-chip DIE which has got 4000pins, is there any other method instead of using text or excel file of 4000 lines. If we use DIE generator, how to add net name for those DIE pins? or any other options ~~Thanks~~
  • BillAcito
    BillAcito over 14 years ago
    You can auto-create nets on the pins, or load a net list onto the pins you have created (under the "Logic" menu, and File-->Import Netlist and Logic). If you have access to the die design DEF or OA, you can also use that to load the die (with net assignment included).
    Bill
  • lifeuistanea
    Hi Bill, Yeah, i know about logic auto create nets. So, will try out DEF method. ~~Thanks ~~
