  2. Allegro X APD
  3. DIE/ BGA rotation, before and after generation
  • Subscribers 68
  • Views 16233
yitch
yitch over 14 years ago
Hi, does anyone know how to rotate the die or the bga before and after rotation? Currently working on a stacked die package. Would prefer to know how to do it after generation, but for completeness if there is a method to do it before that would be great as well.
Thanks!
  • BillAcito
    BillAcito over 14 years ago
    I'm not sure what you mean by "before generation", but once placed:
    In SiP, the Die Stack Editor tool has a rotation value for each die in the DIE tab.
    In APD, you can select the symbol, RMB, and select "Spin".
    Bill
  • Tyler
    Tyler over 14 years ago
    BillAcito has it right. While some of the die and BGA creation tools, like the BGA/Die text in wizards, allow you to specify the rotation when the component is created, that is not available in all flows. What is available is, after placement, the ability to rotate, move, and mirror the component. You can do this using:
    Edit -> Move (allows for rotation as well as movement; available for both APD and SiP users)
    Edit -> Spin (allows for rotation only; available for both APD and SiP users).
    Edit -> Diestacks... (allows for rotation, movement, and pad layer change; available only for SiP users).
    I believe stacked die packages are only supported in the SiP products, so with luck that is what you are using. If so, the die stack editor tool is the most comprehensive, as it also gives you options for what to do with the bond shell if it exists (stretch the wires to the new pin locations vs. move the wires, fingers, and die as a single unit) and the ability to change the ordering of the dies in the stack by changing the layer that each die is placed on.
    - Tyler
