  2. Allegro X APD
  3. How to connect traces of different nets?
  • Subscribers 67
  • Views 15160
clifton
clifton over 13 years ago
Hi All
I need to connect traces of different nets, say net A & B at bottom layer, without DRC in SPB16.5.
Is there a property setting that I can use for this purpose? Or there is a waiver setting in CM?
Thank you in advance for the guidance.
 Clifton
  • oldmouldy
    oldmouldy over 13 years ago
    Assign a NET_SHORT property, Pin or Via Pin is best assignment, Shape assignment isn't great, see the propref.pdf in the doc\propref directory of the installation. This will "waive" the DRC for the shorted nets. You can assign this to a Pin in the Schematic and flow this to PCB Editor if you need to document this in the schematic.
