  2. Allegro X APD
  3. Merge shapes using axlShapeMerge
  • Subscribers 69
  • Views 16254
kwlee
kwlee over 13 years ago
Hi
 Please give me anyone's advice...
1. Using below code, I expect only shapes in some layer can be picked in obj, but obj contains shapes in all layers. Is it normal??
  axlSetFindFilter(?enabled "shapes" ?onButtons "shapes")
  axlVisibleDesign(nil)
  axlVisibleLayer("some layer" t)
  axlSingleSelectBox()
  obj=axlGetSelSet()
 2. Certain layer is filled with many of shapes, How can I merge each other.. I'd like to merge all shapes, if they are connected each other.
 - I tried below code to do.. but it took too much time and not that successful.. since when I use 'axlShapeMerge(a b nil)', members of list b should be connected to a.. unless return error and skip this function...
 allShapes = getAllshapes(some layer)
 foreach(shape allShapes
  when(shape->bBox
   axlClearSelSet()
   axlSingleSelectBox(shape->bBox)
   slist=axlGetSelSet()
   foreach(s slist
     when(axlShapeMerge(shape s 'check) shape = axlShapeMerge(shape s 'quiet) )
  • aCraig
    aCraig over 13 years ago
    Try this
    shapes = axlDBGetShapes(someLayer)
    axlShapesMerge(car(shapes) cdr(shapes) t 'quiet)
    It's possible that all shapes will NOT merge. Only shapes that overlap car(shapes) will merge. So you might need to run it a couple of times which shape has the most overlapping shapes.
    Craig
