  2. Allegro X APD
  3. cross on Power and Ground pins
  • Subscribers 67
  • Views 15493
admin
admin over 13 years ago
Hi, a cross "X" is found on each ground and power pin when i create BGA or flip chip using text-in method.
is there a way to make the cross invisible?
  • Tyler
    Tyler over 13 years ago
    From your description, it sounds like what you're seeing are the ratsnest markers for power/ground. You can:
      - Set the NO_RAT property on the (set of) nets or
      - Turn off display of the rats for the nets in question,
    Either would work fine for your purposes, I think. The choice is up to you, depending on whether you want to see them again in the future or never at all.
    - Tyler
