  2. Allegro X APD
  3. Dynamic Shape not filled in APD16.6
  • Subscribers 69
  • Views 16900
tatets
tatets over 12 years ago
I'm having a problem with dynamic shape placed on conductor layer. It's giving me an unfilled or empty status whenever I placed the shape on top of a BGA pad. But if I tried to just place a dummy shape outside the package, it fills. Please shed light.
Thanks.
  • BillAcito
    BillAcito over 12 years ago
    Same net or differnt net?  What is the clearance rule, pin to shape? Dynamic follows the clearance rules you have set.
  • tatets
    It's of the same net. pin to shape is 0 at same net and 13um for different nets. thanks.
  • mikem
    mikem over 12 years ago
    Look at the local shape parameter settings.  If you want to "merge" the same-net shape with the pad, set the Thermal relief connect for SMD pins to "Full Contact".  If different nets are in close proximity to the shape, you may need to adjust the shape suppression setting, under the Void controls tab in the shape parameters, to something smaller.  The shape me be voiding back to a size smaller, than what is allowed with your current settings.  If this is the case, the shape will not fill.
  • tatets
    Thanks for the help. it's working now.
