  2. Allegro X APD
  3. [skill code] Changing layer name
  • Subscribers 68
  • Views 15220
kwlee
kwlee over 12 years ago
Hi
I tried to change layer name from "Top" to "M1" using skill function.
layer dbid->name = "M1" .. this code return read only error.. is there any fuction for this?
  • Tyler
    Tyler over 12 years ago
    I do not know of any function to do this. Most likely, you would need to write skill that would run a script / command shell commands to open the cross-section editor and update the name there, then close the form again. You could also submit an enhancement request to Cadence asking for a function to rename a conductor layer.
    Any reason you're doing this on the fly, instead of reading in the cross section from a techfile? That way, you could configure everything, including the material, thickness, type, etc. based on your library of stackups based on the technology for the current design.
    - Tyler
