  2. Allegro X APD
  3. allegro free viewer 16.6 missing cdnZlib.dll ?
  • Replies 8
  • Subscribers 71
  • Views 27740
travoltafab
travoltafab over 11 years ago
I had to move from Allegro free viewer 15.7 to 16.6. uninstalled 15.7 and then installed as administrator ( for all users) the 16.6. installation successfully completed.
However on startup i got an error stating it is missing cdnZlib.dll, hence it doesn't starts.
Any help  here ?
Note: Computer is windows 7.
thanks,
br,
fabrice
  • travoltafab
    well, i uninstalled, download again the install, reinstalled as administrator.. and ... it worked.. don't ask me why, i wouldn't be able to tell you unfortunately why it is working now. (thanks for Oldmouldy the proposed solution could't try it).br, fabrice
  • Duc Nguyen SV
    Duc Nguyen SV over 6 years ago
    in switch you should chose the right ver what you are running
    Note : run it with RMB " Run as administrator"
  • sanjay baghela
    sanjay baghela over 5 years ago in reply to Duc Nguyen SV
    regards
    best seo expert in india
