  2. Allegro X APD
  3. PowerSI - Extrapolation difference in Adaptive Frequency...
  • Subscribers 69
  • Views 2604
PowerSI - Extrapolation difference in Adaptive Frequency Sweep
sabari N
sabari N over 10 years ago
We are simulating the power impedance of critical power nets using PowerSI. The port impedance is set at 0.1ohm. The frequency sweep used is from 0 to 3GHz, ADAPTIVE SWEEP.
In adaptive sweep the result at lower frequency are obtained by extrapolation. In the simulation we run, we get some results with good extrapolation. In some random cases we get not so smooth, discrete values at lower frequency.
Which parameter decides this extrapolation? Why there is difference in result between 2 simulation run on the same board?
  • Ashwins
    Ashwins over 10 years ago
    Thank you for posting the great content……I found it quiet interesting, hopefully you will keep posting such blogs…http://www.webdesigncourseinchennai.in
