  2. Allegro X APD
  3. Moving wires
  • Subscribers 68
  • Views 18799
Moving wires
MaxS
MaxS over 9 years ago
Does somebody know a shortcut (funckey) to move wires after wirebonding?
  • BillAcito
    BillAcito over 9 years ago
    To move the wire attachment point on the pin or bondfinger? The wire bond Application Mode puts most of the functionality on your RMB.
    Bill
  • MaxS
    Yes, it is. But instead of cliking RMB on each bondfinger and selecting "Move" I want to use a funckey. I tried to type a such variable: funckey h "prepopup; pop dyn_option_select @:@Move; wbedit_move " in my env file, but it won't work.
    I need to figure out in syntaxis. I think something is missing in the string.
  • MaxS
    MaxS over 5 years ago
    I've found the answer. Maybe it will help someone.
    If you want to move wires along a guide path or between them faster, just use this hotkey: funckey x "prepopup -cursor ; pop dyn_option_select @:@Move"
