  2. Allegro X APD
  3. How to add resistor models in the Power SI[Model Extraction...
  • Subscribers 68
  • Views 2846
How to add resistor models in the Power SI[Model Extraction]
sthotakura
sthotakura over 7 years ago
I am able to add the capacitor models to the components which are placed in the signal path[AC coupling capacitors], on the same signal path I have a resistor also.
How to add models to the resistors[Do we have default library for resistors? similar to capacitors]
Where can I get resistor models[if available outside]
