  2. Allegro X APD
  3. plane via/antipad clearance
  • Subscribers 68
  • Views 6185
gselli
gselli over 7 years ago
Hi all, I have a basic question related to the the plane via clearance in allegro apd. I know the design has 50um via plane clearance, however, it is not defined in the via padstack and when I go on the global dynamic shape parameters, it shows DRC. I am having a hard time finding the rule, so I was hoping that someone can point me to the right location within the tool to look for this
w/ regards,
Giuseppe
  • Tyler
    Tyler over 7 years ago
    Hi Giuseppe,
    If you open the constraint manager tool, and go to the spacing constraints, you should be able to find the via columns under the “shape to” section. This is where you’ll find the values, sorted by layer, that you’re looking for. When the shape global parameters is set to DRC, this is the value that is used for the clearance. You can create different net groupings, constraint regions (areas), etc. to customize the values between different nets, or in diffeeent areas of the board, not just on a per layer basis.
    Let me know if you can’t find it there, and I’ll see if I can get some pictures to post for you. The table in constraint manager is large, but you’ll find it!
    - Tyler
  • gselli
    Tyler,
    thank you for your suggestions and explanations ! I tried to go in the allegro constraint manager, under spacing constraint, i have found the column that says Shape To >> , but it shows All and there are three asterisks *** and no values ? DO you think I am doing something incorrect here ?
    w/ regards,
    Giuseppe
  • Tyler
    Tyler over 7 years ago in reply to gselli
    If you double click on the Shape To >>> column header, it will expand to show all the different other object types. Sorry, I forgot to mention that. You’ll see *** if there are multiple values. From there, if you want to edit the values, you might need to expand the layers to get to the layer that you want.
  • gselli
    thanks ! I have found it ... The tools is excellent, but quite overwhelming for a someone like me who is not a daily user, would you reccomend a good document to get up and running so that I can make changes to design and look for what-if-scenarios ? I am looking at moving vias, changing antipad, moving diff pairs, and so and so forth.
    Thanks again for your help,
    Giuseppe
