  2. Allegro X APD
  3. How to check a cluster of same net vias spacing, with have...
  • Subscribers 71
  • Views 20488
How to check a cluster of same net vias spacing, with have no shape or cline covered
Duc Nguyen SV
Duc Nguyen SV over 6 years ago
Hi all,
I have a question regarding the manufacture : how to check a cluster of same net vias spacing, with have no shape or cline covered
  • YongLee96
    YongLee96 over 3 years ago
    I'm also interested in this issue, does anyone have a way to check them?
  • zpofrp
    zpofrp over 2 years ago
    i use allegro package designer,i dont know allegro PCB。
    allegro constrain manager →assembly →design→package substrate → any metal to any metal spacing
  • TramLe
    TramLe over 2 years ago in reply to zpofrp
    any metal to any metal spacing can be used to check for missing cline or shape between the same net vias, as seen in the case of via 5:6 to via 4:6 in the above picture, as these vias are separate. However, with 0um spacing between via 4:6 and via 4:6, it does not check.
  • zpofrp
    zpofrp over 2 years ago in reply to TramLe
    So,Is there any other way?
  • TramLe
    Hoping someone else in the forum can provide an answer.
