  2. Allegro X APD
  3. Dynamic Package Height
  • Subscribers 70
  • Views 17657
Joewi
Joewi over 6 years ago
Is there a way to set a dynamic package height for a symbol that would take into account the stackup thickness?  We have several configurations where different stackups are required but the allowable insertion space doesn't change.  Unfortunately, the backside of the PCB has multiple height restrictions, so a blanket calculation and change would be tedious.
  • jc teyssier
    jc teyssier over 6 years ago
    I agree this feature is missing;
    One "bad" solution: for such component, you can create ine symbol per cofiguration, say 1.6  tjicknes or 2.4mm thickness pcb. Let thelm heave same name and put them in diffrent directory.
    Exemple: mylib/pcb/packages/pcb/1mm6_thick and mylib/packages/pcb/2mm4_thick
    Then you have to set the correct psmpath for each project.
    Not a good solution (it is prettydangerous since component may be modified/corrected and not the similar one for other thickness; you may point to wrong path,...) but actually it will work.
    If you have mutliple thickness on same pcb, this will not work. In such case i think the actual tool can not handle it.
    To Cadence team: maybe add the possibility to define a negative value to PLACE_BOUDARY_TOP?
    Jean-Charles
  • Joewi
    Joewi over 6 years ago in reply to jc teyssier
    This is how we currently handle it too.
    Maybe I'll submit a ticket for this enhancement.
  • RFinley
    RFinley over 6 years ago
    I believe component height DRCs are intended to measure the height of the component, not involve the thickness of the stackup.
    I have never heard of layout software that took the board thickness into account.
    Allegro and Orcad can check for interference between a board assembly and an imported enclosure step file.  Can  you use this updated method?
  • jc teyssier
    jc teyssier over 6 years ago in reply to RFinley
    Some component have part (mainly connectors) passing thru the pcb in cutouts. Step file are not always available Disappointed
    This kind of compoent have this problem of part passing thru:
    www.vincotech.com/.../flow-2.html
    I guess Joewi problem is not just for pins only (i personnaly add a place_bound_bottom with small heigt at pin location)
  • RFinley
    RFinley over 6 years ago in reply to jc teyssier
    Missing Step models.  Quite familiar with that.
    WFH to study Solidworks with an online service called "Solid Professor".  Just have to hide this from our "fake-swamped" MEs.
