  2. Allegro X APD
  3. How to map Escape key to Cancel in APD v17.2?
  • Subscribers 69
  • Views 17653
sivavayu
sivavayu over 6 years ago
Coming from a different tool, Mentor Layout, I am more used to using Escape key to cancel any command. I tried different alias versions like below. None of them seem to work.
alias Escape Cancel
alias esc cancel
alias escape cancel
funckey esc cancel
funckey escape cancel
Also, what is the symbol for "Alt" in hotkeys?
For Ctrl, it is "~". For Shift it is "S". For Alt, I wasn't able to find one.
Any help is appreciated.
Thank you.
  • masamasa
    masamasa over 6 years ago +1
    i use the following funckey: funckey Esc "cancel" i do not think you can use alt alone but with function keys, ctrl and shift keys funckey AF1 "cancel" this one is alt+F1 funckey ~AS1 …
  • masamasa
    this one is alt+F1
    funckey ~AS1 "cancel"
    this is alt+shift+ctrl
  • sivavayu
    sivavayu over 6 years ago in reply to masamasa
    Thank you. Works perfectly!
