  2. Allegro X APD
  3. Syntax for Alias and Funckey commands
  • Subscribers 69
  • Views 23713
sivavayu
sivavayu over 6 years ago
Can someone point to a resource for syntax for Alias/Funckey scripting? I came across very useful hotkeys online and would like to write my own, but limited by the lack of knowledge of the syntax.
Some examples I came across online are as shown below. I can understand them, but I am sure the capability of this funckeys is limitless, if basic syntax is known. I could not find this syntax anywhere in Allegro help.
Using a shift or ctrl key in combination with mouse wheel. Add the following line in the env file and start PCB Editor
button Swheel_up "FORM mini Alt; FORM mini Alt_subclass XXXXX; pop bbdrill -cursor"
While routing press the shift key and roll the mouse wheel in upward direction to place the via. To use the control key in place of shift then replace 'Swheel_up' with 'Cwheel_up' in the above line. Similarly if you want to use downward direction of wheel then replace 'Swheel_up' with 'Swheel_down'. If you want to use it with working layer model instead of alternate layer replace 'Alt' with 'WL'.
Source: https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od00000004uHFEAY&pageName=ArticleContent
Siva
  • masamasa
    masamasa over 6 years ago +1
    you can refer to the following link http://referencedesigner.com/tutorials/allegro/allegro_page_29.php you can always use "scriptmode +e" to find out the actual command. just type scriptmode e+ at…
  • masamasa
    just type scriptmode e+ at the command line then you will be able to see the actual syntax of the command you are using.
  • sivavayu
    sivavayu over 6 years ago in reply to masamasa
    Thank you very much! This is very helpful information.
  • sivavayu
    Any place where I can find what syntax can be used for buttons and keys?
    For example, I have seen these cases:
    • button SWheel_up
    • SLeft
    • SRight
    Thanks.
  • masamasa
    masamasa over 6 years ago in reply to sivavayu
    for shift+wheelup
    button Swheel_up "copy"
    for shift+ctrl+wheelup
    button SCwheel_up "copy"
    for ctrl+wheelup
    button Cwheel_up "copy"
    for shift+left
    funckey SLeft "copy"
  • masamasa
    these sites might help you as well.
    https://www.youtube.com/watch?v=xnT0PlR17-A
    https://www.flowcad.de/AN/FlowCAD_AN_PCB_SiteAndHome.pdf (pages 10&11)
    https://www.ema-eda.com/sites/ema/files/ALLEGRO_Cheatsheet.pdf
    https://www.ema-eda.com/sites/ema/files/ALLEGRO_Cheatsheet_Bonus.pdf
