  2. Allegro X APD
  3. Window selecting objects like vias, c-lines, and shapes...
  • Subscribers 69
  • Views 16368
Window selecting objects like vias, c-lines, and shapes of a particular net
sivavayu
sivavayu over 6 years ago
How to select a objects related to only a set of nets that I am interested in? When I window select over multiple objects, I want the selection to be limited to a filter of few nets only. There is a net filter in Mentor. I don't see a similar option in APD. Find By only highlights particular nets, but doesn't limit selection to those nets. Can anyone help?
  • masamasa
    masamasa over 6 years ago +1
    you can filter the objects by nets on the find filter you need to open "Find by query" then set up the filter and save the query as shown below. when you select the object, you check "By Saved…
  • masamasa
    when you select the object, you check "By Saved Query" and select the one created.
    in my case i created a query named "gnd."
  • sivavayu
    sivavayu over 6 years ago in reply to masamasa
    Thank you for your response. I am glad that this feature exits! I spent a lot of time in finding this feature.
