  2. Allegro X APD
  3. Show measurement window does not open
  • Subscribers 70
  • Views 24850
Andy M
Andy M over 6 years ago
When I try to use the show measurement tool in APD+ free physical viewer in Win10, the show measurement window does not open.  I am able to get the show element window to open but no luck with the show measurement window.  I tried deleting the .geo file in my pcbenv directory but no luck.  Any suggestions??
FYI..I just did a fresh install of Allegro IC Packaging 2020 APD+ Free Physical Viewer 17.4-2019 S008 [7/14/2020] Windows SPB 64-bit Edition
Andy
  • masamasa
    masamasa over 6 years ago in reply to Andy M +1
    the gui might still be opening on the second screen. you can try windows+p to see if "pc screen only" is selected
  • Andy M
    Andy M over 6 years ago in reply to masamasa +1
    That did it, thank you very much!!!!
  • masamasa
    did you use dual monitors previously?
    locate your pcbenv folder and delete the allegro.geo file to see if the gui comes back.
  • Andy M
    I have used dual monitors and I have tried this and it did not fix my issue Disappointed
    Thank you for the suggestion!
    Andy
  • masamasa
  • Andy M
  • wgr2010
    wgr2010 over 3 years ago in reply to masamasa
    This worked for me; however, I only have one screen now.  How do I set it so I have duplicate screens and can use measure and other things in 17.4?
