  2. Allegro X APD
  3. Scripts or commands to create the package stackup
  • Replies 38
  • Subscribers 69
  • Views 46332
sidm
sidm over 6 years ago
Hi All,
are there any commands or scripts that can help to create package stack-up from scratch in an automated manner.
Something that can take in no. of conductor , dielectrics layers along with the thickness and material information and dump a tech file or mcm to be imported into SIP ?
I also wish to parametrize the package dimensions.
regards
  • sidm
    sidm over 6 years ago in reply to masamasa
    thanks ,is it fine to define mask as a dielectric layer ?
    For the package on package each package stack up has a solder mask for itself. So I wish to define solder make separately for them.
  • masamasa
    masamasa over 6 years ago in reply to sidm
    yes it is fine.
    i have designed an interposer on a package as shown below.
  • sidm
    Thanks , can you please also advise how can I place balls in the gap area of a POP structure (by GAP area I am referring to the air gap separating the 2 packages) ?
  • masamasa
    you can simply add one conductor between the 2 solder masks.
    you need to make sure that the padstacks connecting the upper and lower packages have the conductor you have just added as well.
  • sidm
    Hi All,
    Is it possible to combine 2 sip packages through some utility instead of manual work ?
    For example I have a 4 layer OSAT database and I need to add a different interposer database to this original 4 layer database ?
    Also can you please share any documents for doing silicon interposer design in SIP/APD ?
    regards
