  2. Allegro X APD
  3. Scripts or commands to create the package stackup
  • Replies 38
  • Subscribers 69
  • Views 46331
sidm
sidm over 6 years ago
Hi All,
are there any commands or scripts that can help to create package stack-up from scratch in an automated manner.
Something that can take in no. of conductor , dielectrics layers along with the thickness and material information and dump a tech file or mcm to be imported into SIP ?
I also wish to parametrize the package dimensions.
regards
  • masamasa
    masamasa over 6 years ago
    you can always import and export the cross section technology file from the cross secton editor.
  • sidm
    sidm over 6 years ago in reply to masamasa
    Thanks for the reply, how do you define a package on package structure using this cross section editor? Any doc or  example for this ?
    I think It doesn't allow to define soldermask layers more than once inside the editor. Suppose I need to define soldermask layers for both the package of the pop.
  • masamasa
    masamasa over 6 years ago in reply to sidm
    you can refer to the following youtube to define the cross section.
    https://www.youtube.com/watch?v=L_APAvB3d4o
  • sidm
    Thanks for the reply  this doesn't have multiple solder_mask addition to the stack up right
  • masamasa
    on the cross section editor you can place solder as dielectric above "top" conductive layer and another solder as dielectric below the "bottom" conductve layer.
    i also define them on the padstack and soldermask_top and soldermask_bottom on the non conductive section of the stackup.
