  2. Allegro X APD
  3. Scripts or commands to create the package stackup
  • Replies 38
  • Subscribers 69
  • Views 46373
sidm
sidm over 6 years ago
Hi All,
are there any commands or scripts that can help to create package stack-up from scratch in an automated manner.
Something that can take in no. of conductor , dielectrics layers along with the thickness and material information and dump a tech file or mcm to be imported into SIP ?
I also wish to parametrize the package dimensions.
regards
  • masamasa
    masamasa over 6 years ago in reply to sidm
    you can use the net logic command for the net name change on the pins.
    for the pin name change, you would need to update the symbol.
    you need to make sure that the netlist is updated after all the changes you make.
    if you have the netlist and have many pins to change for the net name change, you can simply import the netlist as well.
    this would be much easier as you do not have to change the net name of the pins one by one.
  • sidm
    sidm over 6 years ago in reply to masamasa
    Thanks for the reply. Can you please elaborate a bit ? The pin name let’s say need to be renamed from RFIN to rfin and the net name from VD2 to Vd2
  • masamasa
    first, you need to update the symbol using the new pin name of rfin.
    when you update the symbol (dra file), make sure you update the psm file and the device file as well.
    after that, you update the symbol on the mcm file by the refresh symbol command.
    i usually change the symbol name to verify that the symbol is really updated or not.
    for the net name change, you need to import the netlist with the Vd2 name, or change the net name one by one by the net logic command.
    if you change it one by one, make sure that the netlist is updated after the change.
