  2. Allegro X APD
  3. BUG about Microns Unit accuracy
  • Subscribers 69
  • Views 14464
ichliebedich
ichliebedich over 5 years ago
Hi all,
I tested both APD and Allegro PCB at 17.2 version.
I found some bug about units accuracy for Microns.
at the first time it set the Accuracy value with 3 (see the pic below)
even if I can set the value to 4, action was canceled and back to original value 3 without other change value. (other value didn't changed to 4 accuracy)
and I also set the value to 2 so made it like below
after then, I can not increase the value to 3 again...
when I increase the value to 3, the action was canceled continuously..
Is there any way to set the Accuracy value to edit some Allegro script manually?
regard.
  • RFinley
    RFinley over 5 years ago
    I transcribe GDS data from Virtuoso and MWO for RF module substrates.
    Just can't expect Allegro to give me sub-10um accuracy if I can't fab it.
  • ichliebedich
    ichliebedich over 5 years ago in reply to RFinley
    there is GDS file which was created by Allegro, but it seems like binary file so I can't read it
