  2. Allegro X APD
  3. Changing multiple pin text names
  • Subscribers 70
  • Views 20540
RSC21
RSC21 over 5 years ago
Hi all, first time to post here.  Is there a way in where I can easily change pin text names in one shot (bring up a list, change it from before to after) and then have Cadence add those pin text names instead of changing them one at a time?  I created a 135 pin BGA footprint but my array names (A1, A2, etc.) were supposed to be in a vertical column (top to bottom), not horizontal (left to right).  It would take me forever to change them one at a time.
In the schematic editor, this is easily done as you can edit pin names and pin numbers.  I was wondering if you can do the same in the footprint environment.  Thanks in advanced!!
  • steve
    steve over 5 years ago +1
    Yes - Try the Layout - Renumber Pins option. If this doesn't give you what you need try File - Export CSV Pin File, this dumps out a csv file that can be edited in Excel you can then use File - Import…
  • RSC21
    I also forgot to ask if you're create a BGA and you want to create pins (A1-A17) then create another row (B1-B17), etc. can you manipulate the right/left, up/down to do this?  If you just set your first pin name as A1, then choose 17 pins to the right and 17 down, it will just create pins from A1-A289 (17x17).
  • redwire
    redwire over 5 years ago
    No, not that way.  However, you can use the wizard to quickly create the row/col again in the correct orientation.   If you need to merge the new symbol with some old annotations (silk, comments, etc..) you can use the subdrawing export import feature...
  • redwire
    redwire over 5 years ago in reply to RSC21
    Not in the wizard.  If doing manually then you need to set the starting pin number of each col (or row) and add just those 17; so yes you would have to do that 17 times.  Wizard is much easier as it understands row col.
  • RFinley
    RFinley over 5 years ago in reply to RSC21
    working for a company that designs chips and has marketing-driven pin name changes, capture the symbol pinout in an excel spreadsheet makes it easier to update.   Did not know about the CSV function.
  • steve
    Yes - Try the Layout - Renumber Pins option. If this doesn't give you what you need try File - Export CSV Pin File, this dumps out a csv file that can be edited in Excel  you can then use File - Import CSV Pin file and make the changes.
