  2. Allegro X APD
  3. Import of "was/is" list for ref des
  • Subscribers 70
  • Views 4914
SiPguy
SiPguy over 5 years ago
Hi, Is there a way (without using skill) to import a "was/is" list of reference designators? I have a text file with 2 columns, the WAS column has the current ref des for an APD+ design and the IS column has the new ref des I want to change to.
Thanks in advance
  • masamasa
    masamasa over 5 years ago
    u can simply import a netlist with new reference designators without old ones.
  • DavidJHutchins
    DavidJHutchins over 4 years ago
    the external command 'reftxt' will read a was/is file & an input design to create a new output design, below is the contents of the help file:
    reftxt: Allows renaming of a design's refdes via a text file.
    Command line:
    reftxt <rename file.txt> <in design> [<out design>]
    If out design is not given overwrites the in design.
    Logfile: reftxt.log
    Rename file syntax; one refdes rename per line:
    <current refdes> <new refdes>
