  2. Allegro X APD
  3. 17.4 HF019 - GPU Support - Skeletal View gone !
  • Replies 13
  • Subscribers 71
  • Views 15093
UlfK
UlfK over 5 years ago
Having downloaded and installed the latest HF for 17.40 I was greeted with a splash screen that my Nvidea Quadro (K2000) board was detected and asked if the GPU support should be switched on. Accepting this, the display changed and the response was indeed quicker but: The skeletal view of the various elements was not longer possible to achieve. I have used this over the years with the possibility to dim and set skeletal view options according to the sliders in the viewing pane.
It is not also possible to adjust the opacity of shapes.
Having checked the nVidea Control panel, there are no options that controls this behavior. Toggling priority between graphic and/or GPU computing or adjusting the performance slider have no effect.
It is possible to have the pads tranparent but traces or shapes - No.
I also downloaded HF020 today but could not see any change.
Running W10 x64 Pro on a HP Z420
  • RFinley
    RFinley over 5 years ago
    From the release notes for 7.4.020, GPU acceleration is available for Venture or Enterprise or APD plus SIP/bundle/XL options.
    There are improvements to the 3D canvas for sp20.
    My license is PA-3100 Allegro.  Opacity works normally for me.  Shapes.  Etch.
    I do depend heavily on shape opacity, so I understand your frustration.
    Hp G2 Z4 mini with P1000 NVidia.
  • excellon1
    excellon1 over 5 years ago
    The skeletal view pertains mainly to the center click with the mouse which invokes elements not drawn in full so as to assist in zooming etc. In HF19 non filled pads and shape transparency is working fine via slider as per the norm.
    I think possibly what you might be seeing is related to enabling that GPU support option. If possible try things out with that GPU option disabled..
    One other thing to check is that your video drivers do support opengl. Allegro uses opengl for pretty much all graphics so hence the speed of allegro in this regards.
    Still though Allegro does have OpenGl issues. Since HF08 Highlighting of any object has slowed down in a big way. With your cursor you can move it over objects at a moderate pace and if something like symbols is checked
    in the find filter the entities will actually not highlight. Same for clines or anything else. The functionality for highlighting is a "Dead Stick"
    Altium, Pads and even lower tier products do not have this issue. Highlighting speed in Allegro 17.4  has been nothing short of total "Junk" since HF8 service pack and all these release since that time have the same problem in this regards.
    There are other hidden Gems in there too. Slightly off topic for users on Orcad with current upper tiered releases is that the timing vision functionality does not work because the software dependencies for sigrity components that used to
    be included with allegro are no longer included. That reminds me of purchasing a car to find out Oh BTW we no longer include a spare tire after the fact when one needs it. Pretty sad IMHO.
  • RFinley
    RFinley over 5 years ago in reply to excellon1
    Ok.  Hyundai wanted $300 for a spare tire.  That's 3 years of AAA service so...
    Ex, I have always appreciated your wisdom and insight.
    I have an HP G2 Z4 mini, that is about 8 inches square and 2 inches tall.   16gb of RAM   Not remarkable, IMHO.
    I don't think I have ever experienced any of your problems.
    I dug into the high-speed ILS to get a more complex board to navigate like the Xilinx HW-Z1-ZCU106_Revision_1_0.brd file.
    I am not experiencing any lag in 17.4.020 even when rolling over the ground net.
    Have to ask what machine you are using?
    Do you have an NVidia or AMD graphics coprocessor.    My HP has a NVidia Quadro P1000
  • excellon1
    excellon1 over 5 years ago in reply to RFinley
    Hi RF
    Machine is a Ryzen 5 3600x with a Radeon Pro WX4100 vid card,  32GB ram, Intel ssd etc. OS is win 10. Desktop box.
    On the exact same machine hardware and the exact same OS with 17.2 no issues exist.
    Try this. Draw 10 parallel clines. Pass your mouse over them at a moderate to fast pace. Do they all highlight individually without delay or do some get missed ?.
    Another thing to try.
    Disable the start screen. Enable the full screen cursor. Restart Allegro.  how is the zoom in and out speed. ?
    Total crap here....
    Re-enable the start screen and restart allegro. Does the zoom in out performance increase ?
    Appreciate your insight on this, let us know how it looks there. If good maybe I need a different vid card.
    Thanks.
  • RFinley
    On my machine, when scanning over a group of CLINES on the Xilinx design I mentioned, it doesn't highlight about half of them as I move the cursor quickly using the cross cursor.
    Switching to infinite cursor, I have to pause for the net to highlight.   I haven't needed to use the full-screen/infinite cursor.
    With the smaller scale of projects, I can't complain about this.   I spend too much time in P*DS and A*ium to notice differences between 17.2 and 17.4 (had to go back to 17.2 for a while after adding a dodgy step model that 17.4 didn't like.)
    Do you highlight with a stipple pattern (Enormously handy for me but not sure if the GPU helps here) or do you use a single color override or the shadow mode?
    Probably doesn't matter.  But, the Radeon Pro card is not on the 17.4 release notes Page 12 for Supported GPUs
    I don't think you would need an expensive NVidia card to try.   The P1000 I have with 4gb of DDR4 is designed for workstation-class laptops.
