  2. Allegro X APD
  3. How to change pin number view on Allegro Pacakage BGA pins...
  • Replies 11
  • Subscribers 70
  • Views 24693
How to change pin number view on Allegro Pacakage BGA pins?
ichliebedich
ichliebedich over 5 years ago
Hi All
How can I see the pin number like below in each BGA pins?
my view is below, I don't know how can I change my view like that
regard
  • ichliebedich
    ichliebedich over 5 years ago in reply to steve
    If I hover over the text, I can see like below which said Geometry Pin_Number
    and if I move the text,  the text moves along the central axis of the symbol.
    it's really wired
    • Vote Up -1 Vote Down
  • excellon1
    excellon1 over 5 years ago in reply to ichliebedich
    Hi
    This looks very odd to say the least, but I do know of a method to do what you are seeing. In Allegro one typically assigns a pin number for example A1, A2, A3 etc so as to map the pins for the purpose of generating a netlist from the schematic.
    It looks to me based on your pictures that the text "A" in your picture above is not really associated with a physical pin number at all. Basically what you have is the A which is text that was drawn on a different layer but then that text was changed to the class subclass of "Package Geometry - Pin Number" & yep it is possible to do this, "Yikes"
    My thinking is this was done to kind of give a visual que to the rows on the package. Ideally though the letters A, B, C, D etc outside the package should be on the silkscreen layer and not the Package Geometry Pin layer. Perhaps somebody created that symbol you are using but did it incorrect !.
    By way of a suggestion, the first thing to do would be to verify all pin numbers are correct on the BGA because if not you will have serious issues netlisting.
    Can you confirm if the pin numbers are good/Bad. Maybe attach the DRA/PSM for that footprint as a zip file and I will take a look at it.
    All the best.
  • steve
    steve over 5 years ago in reply to ichliebedich
    So what happens if you hover over an actual pin (not the text). What does the tooltip say?
  • ichliebedich
    if I hove over the pin it say like below
  • steve
    So I opened the BGA you sent and I see the pin numbers displayed correctly. But I'm using an Allegro PCB Designer license 17.4-2019 S022. This may be different to the version/license you are using.
