  2. Allegro X APD
  3. How to change pin number view on Allegro Pacakage BGA pins...
  • Replies 11
  • Subscribers 70
  • Views 24692
How to change pin number view on Allegro Pacakage BGA pins?
ichliebedich
ichliebedich over 5 years ago
Hi All
How can I see the pin number like below in each BGA pins?
my view is below, I don't know how can I change my view like that
regard
  • steve
    steve over 5 years ago
    Setup - Design Parameters - Display tab and turn off Filled Pads, then look at Setup - Colors and under the Geometry window turn on the Pin Numbers layer. You may need to resize / reposition the pin number text.
  • ichliebedich
    ichliebedich over 5 years ago in reply to steve
    thank you, but my pin numbers are set outside of boundary with Matrix form but I want to put inside of each pin
  • steve
    steve over 5 years ago in reply to ichliebedich
    So that is not the pin number text but more than likely text added to an assembly / silkscreen sybclass. Turn off all items in the Colors then turn on JUST Geometry / PIN_NUMBER and you should see what you need.
  • ichliebedich
    yes I did I turned off all color components except the Geometry/Pin_number (look below)
    is it different with allegro PCB and Allegro package ?
  • steve
    Shouldn't be different, what happens if you hover over the pin, the corresponding text will highlight
