  2. Allegro X APD
  3. Error 1 NET but split into 2 CLINE
  • State Verified Answer
  • Answers 2
  • Subscribers 69
  • Views 13322
YongLee96
YongLee96 over 3 years ago
While designing, when I clean DRC I encountered this situation.
The same Net together but separated into 2 independent cline.
If anyone has this problem, please tell me how to solve it, thank you very much.
  • avant
    avant over 3 years ago +1 verified
    It is possible one of the clines is fixed, or belongs to a group.
  • JuanCR
    0 JuanCR over 3 years ago
    Are you sure the vertical (blue) cline isn't just highlighted in blue?
  • YongLee96
    0 YongLee96 over 3 years ago in reply to JuanCR
    It's a temporary highlight when I select cline so only highlight a fragment.
  • avant
    +1 avant over 3 years ago
  • JuanCR
    0 JuanCR over 3 years ago in reply to YongLee96
    Ok ... then maybe I misunderstood. Are your referring to the 90º angle not being displayed as "smooth" transition but 3 separate segments?
    If that's your issue, then you need to go to Design parameters and have "connect line endcaps" ticked:
  • YongLee96
    0 YongLee96 over 3 years ago in reply to avant
    Yep, I grouped it before, and now the problem is solved. Thank you, bro <3<3
