  2. Allegro X APD
  3. Re-size and Re-space of differenetial pairs
  • Replies 7
  • Subscribers 70
  • Views 13241
hailong9
hailong9 over 3 years ago
i'm try to change the width and gap of differenetial pairs, but it only works on the width of line. i can't respace the DP. how can I use this fucation to change the gap of DP? Thanks!
  • JuanCR
    0 JuanCR over 3 years ago
    Hi. Are you using the Constraint manager to do this? Are you using this sheet:
    You can find tips to work with differential pairs here:
    Article (20416966) Title: Tips for using differential pairs in Allegro
    URL: https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od000000050XBEAY
    Hope it helps
  • avant
    0 avant over 3 years ago
    Try defining the differential width and spacing in the physical rules. The only thing I set in electrical rules is the static phase tolerance. If the gap is less than the default minimum, you will need to also define a constraint in the spacing rules.
  • JuanCR
    0 JuanCR over 3 years ago in reply to avant
    So you use the physical constraints only when the gap is lower than default minimum or in general? and I'm curious as why you don't recommend using the electrical gap constraints
  • avant
    0 avant over 3 years ago in reply to JuanCR
    I use physical constraints on all diff pairs, regardless of the gap.  I assign a spacing rule if gap is less than default. The electrical width / gap settings don't work for me.
  • JuanCR
    Interesting. Alright, thanks for sharing
