  2. Allegro X APD
  3. How to check same net spacing for microvias
  • Subscribers 69
  • Views 11123
YongLee96
YongLee96 over 3 years ago
I tried using the Check Same Net Spacing: Micovia To Microvia method. However, it generated too many errors that I couldn't distinguish between "OK" and "Not Good," as example picture. Has anyone experienced this or have any ideas to help me solve this issue?
In addition, I have another issue: how can I show DRC for the case in the image below - where the Shape does not fully cover the microvia?
I sincerely appreciate and highly value any assistance that anyone can provide. Your help is greatly appreciated, and I am very grateful for it.
Many thanks!
  • edhickey
    0 edhickey over 3 years ago
    Please post an image of the "Display - Constraint' report to check constraint resolution.
    Steps
    1. Display - Constraint
    2. Set Find Filter to Vias
    3. Window select 2 vias
    EXAMPLE (ASSUMING YOU WANT TANGENT MICROVIAS)
  • YongLee96
    0 YongLee96 over 3 years ago in reply to edhickey
    This's my constraints report. I set spacing same net: microvia to micro via= 30. because I want to find such places to connect them together by cline.
  • Hoangkhoipcb
    0 Hoangkhoipcb over 2 years ago
    Hi YongLee96!
    Do you have a solution for this problem?
    I like the issue you care about.
    i see, my designs almost similar your design.
    HoangKhoi
