  2. Allegro X APD
  3. APD+ 22.1 on Linux Environment Abnormal Display
  • Subscribers 68
  • Views 10087
APDCloud
APDCloud over 3 years ago
My company is using APD+ on a Linux platform and I have encountered some display concerns as the following:
1. Whenever I hover my mouse over a via, it abnormally zooms in (my screen becomes the color of the drill for example) even though I am not scrolling the mouse wheel.
2. Whenever I select multiple items on the layout (e.g. selecting vias, traces and/or components) the items become invisible and with that, I have to guess the area of selection.
My temporary workaround is to disable the openGL however doing so, it will make all vias, traces, and pads become opaque, and I am not really used to this kind of display setting.
Hope you can help me.
  • APDCloud
    APDCloud over 3 years ago in reply to mahimag +1
    Thanks mahimag . Acknowledged on your email. Currently, I am still waiting for our IT team to get a response about the driver.
  • mahimag
    0 mahimag over 3 years ago
    Hello, which hotfix of the APD+ 22.1 are you working on? To check this you can open APD+ and go to Help > About menu and check the bottom line.
  • APDCloud
    0 APDCloud over 3 years ago in reply to mahimag
    Hello! As I checked, it shows this version: 22.1-2022 S003 [3/19/2023] Linux SPB 64-bit Edition
  • mahimag
    0 mahimag over 3 years ago in reply to APDCloud
    Hi APDCloud, It looks like openGL (Graphic card driver) issue. I will be needing some additonal data to debug this further. I’ll be contacting you through a different channel.
  • APDCloud
    Thanks mahimag. Acknowledged on your email. Currently, I am still waiting for our IT team to get a response about the driver.
