  2. Allegro X APD
  3. Extracting Parasitic RLC on Cadence APD+
  • State Verified Answer
  • Subscribers 69
  • Views 10453
APDCloud
APDCloud over 3 years ago
Hi
Just want to have your comment or maybe help me understand if the Cadence APD+ can extract accurately the parasitic RLC of the layout? And if yes, what parameters or settings should be observed before performing the parasitic RLC?
My customer mentioned that my extractions could be wrong, otherwise the layout is wrong due to large values of inductance and resistance.
Currently, I only know the command "show rlc" and "show parasitic" to get this RLC.
Thank you.
  • TCHA
    TCHA over 3 years ago +2 verified
    The stackup should be accurately entered in APD+ for the parasitic RLC command to give accurate result. RLGC for the given line structure is field-solved. Subsequently, standard transmission line theory…
  • TCHA
    +1 TCHA over 3 years ago
    The stackup should be accurately entered in APD+ for the parasitic RLC command to give accurate result. RLGC for the given line structure is field-solved. Subsequently, standard transmission line theory is used to calculate the impedance value from RLGC.
    You can check the article provided in the below link
    support.cadence.com/.../ArticleAttachmentPortal
    • Vote Up +2 Vote Down
